How to get electronic speedometer to work with 82 T10 4spd manual
Old Dec 30, 2012 | 12:52 AM
jims86's Avatar
Car: 86 Trans Am
Engine: Rebuilt 350 4BBL
Axle/Gears: 10 bolt rear 3.42 gears
I got an 86 Trans Am with the electronic gauges(not digital).It has an upgraded carbed 350,700R4 with lockup converter.CAR HAS NO COMPUTER I am getting an 82 Camaro pace car replica(junk)but good running gear,switching trans,rear end,drive shaft all mounts,torque arm.Question is how do i get the cable driven trans to record speed on my 86 dashboard?
Old Dec 30, 2012 | 02:05 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: How to get electronic speedometer to work with 82 T10 4spd manual
idk what tranny is in the 82 this works if you are going to another 700r4. you take the tail shaft housings off the 2 trannies pull the plastic gear off the output shaft on the new tranny after removing the clip that holds it on. then you take a gear puller and pull the metal gear off your old tranny's output shaft. then install the metal gear on your new tranny's output. after that you put your old tranny's tail shaft housing onto the new tranny.
Old Dec 30, 2012 | 04:44 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Pretty sure that's not going to work... I think the drive gears are different, first, and second, I'm pretty sure there is no VSS readily available for the T10.
jims, I think you're going to need to get a Dakota Digital VSS and buffer for your gauges.
Old Dec 30, 2012 | 09:45 AM
jims86's Avatar
Car: 86 Trans Am
Doesent a vss attach to the cars ECU in some way?As my car has no ECU in it.
Old Dec 30, 2012 | 02:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Not on an 86. Those have a yellow box on the ECM bracket that does the same thing as a circuit in the 90-92 ECMs. The yellow box is used up to 90 and on TBI cars after that. All you need is the VSS and the yellow box, and the wiring between them and the instrument cluster.
Either way, you're still probably going to have to pick up the Dakota VSS as I am unaware of a VSS that fits a T10. The Dakota unit attaches to the speedo cable bullet in place of the cable and outputs the signal accordingly.
Old Dec 30, 2012 | 05:05 PM
jims86's Avatar
Car: 86 Trans Am
Thats a bummer.Can I just use an older cluster with the mechanical speedo?
Old Dec 30, 2012 | 05:51 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yes. If I understand correctly, you're putting the drivetrain out of the pace car into the 86, right? If so, you would need to drill the hole in the bulkhead for the speedometer cable and find a way to run it to the dash. And then you would need to swap over the odometer parts, which is easier said than done.
Old Dec 30, 2012 | 05:54 PM
jims86's Avatar
Car: 86 Trans Am
I got a guy in Massachusettes that has a Mechanical speedo Cluster I believe they came in base models and are only 80mph
Old Dec 30, 2012 | 05:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Hold up. I just looked up "speedometer gears" and found that the T-5 uses a similar setup. All you need is the corresponding sensor, buffer box, and wiring to the cluster. The instructions are in the Tech Articles on the main TGO page.
:edit: You're going to need to make sure of what colors the gears are that are currently in the T10 if you want to swap to a VSS, because you will need to buy a new speedo driven gear for the VSS, and you will need to make sure you know what gears are in the rear axle as well as the tire size you will be using.
Old Dec 30, 2012 | 08:46 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://tpiparts.net/inc/sdetail/10956/7586
Old Dec 30, 2012 | 08:56 PM
jims86's Avatar
Car: 86 Trans Am
My car has no ECM I run a 1972 rebuilt carbed 350
Old Dec 31, 2012 | 05:01 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Again, as I said before, the 86-89 (all) and 90-92 TBI cars with the electric speedo used a buffer box between the VSS and everything else because the ECM was incapable of interpreting the VSS signals in such a manner they could drive the instrument cluster. The buffer took the VSS signal and split it into 3 parts, for the cruise control, instrument cluster, and ECM.
If you didn't cut the buffer box plugs in the dash harness on the 86, all you need is the buffer box and an 86-89 T-5 VSS, which will plug right into your stock harness. However, the availability of the driven gears for the VSS is limited, so you need to be careful. And, if necessary, you may need to do some junkyarding and find a car with a similar setup as you plan on using (rear axle ratio) and pull the VSS and speedo driven gear out of the car.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
beachrodder
Aug 7, 2015 04:27 PM
