Fuse #11 (Int Lights) Blowing
Old Jan 21, 2013 | 10:26 PM
NewKindOfClown's Avatar
Car: '91 Z28 / '93 Jeep Wrangler
Engine: 5.7L L98 / 4.0L I6
Transmission: 700r4 Auto / 32RH Auto
Axle/Gears: Posi 3.23 / Open 3.07
1991 Camaro Z28 5.7L with every option except disc brakes.
Since I got the car, fuse 11 (20amp) has been indiscriminately blowing. It controls interior lights, door locks, and rear hatch release. My power mirrors also stopped working today, but I don't know if that's the same fuse. Unfortunately, the PO thought he was an electrician, and I've yanked over 200ft of hot non-factory wire that was hidden behind the dash and under the carpet. I haven't removed any factory wiring. I have not been able to consistently replicate the trigger; it seems to be random in occurrence.
I'm simply wondering is there a known issue to cause Fuse #11 to blow, or do I need to start tracing wires?
Thanks, as always.
Old Jan 28, 2013 | 04:33 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Cruisin’ For A Fusin’
The most likely cause is a bad cigarette lighter.
Disconnect to verify.
Happy Racing!
If We Don’t Get Cawt We Ain’t Cheatin
Old Jan 28, 2013 | 07:47 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Fuse #11 (Int Lights) Blowing
Main thing to do is to undue what the PO did. Remove aftermarket wires so it doesnt look like a spagetti factory under the dash. That fuse is the ACC fuse. Like you said, it controls interior lights, door locks, hatch release. It also powers the mirrors, cig lighter and also the horn relay for the horn. Shorts can be hard to find. Main thing is to try and find whats causing it to blow consistantly. Opening the door, using door locks, etc. Does the fuse blow out of nowhere? A little investigative work will go a long way.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
GTAman
Mar 15, 2019 11:40 AM
Omega
Aug 10, 2015 12:46 PM
