bad igniton switch?
bad igniton switch?
I am going to look at this 87 camaro tomorrow. The kid told me he thinks the ignition switch is bad. He said the car starts but the starts stay engaged and kills the battery. Does this sound like a bad switch and if so How can i by pass it just so i can get it home?
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: bad igniton switch?
I would take one of those manual starter buttons to by pass the switch, turn the key to the ON postion, then (if the started didnt engage) use the manual start switch to turn the starter.
Here is the switch I was talking about. switch
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
( purple wire ) up to the battery.
Touch wire to batt Pos terminal and engine should crank
meaning the Ign switch is not returning back to the off position and cutting power to the starter once the engine has started
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Or the starter/flexplate is toast. Either way, now it's also time to check the starter gear and flexplate for damage and chewed teeth.
Car: 82 Z28
Transmission: T400
86IROC112
Aug 17, 2015 02:00 PM
