Under Hood lighting question
Old Feb 2, 2013 | 03:50 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
I tried to do a search before posting but came up empty.
Here's my dilemma. I have an 83 Z28 with the steel hood. The under hood light was working with no problems, but I wanted to spice it up a bit for car shows. I bought 4 24" led strips to attach under the hood to replace the ancient incandescent bulb. It looked pretty straight forward... single positive wire to the bulb, grounds out to the hood... so I snipped the wire and connected everything up. There were 2 bolts holding the light to the hood, one holding a wire that runs into a loom, the other not. If I ground the leds to the bolt with the wire, they stay on all the time, even with the hood closed. If I ground them to the other bolt, they dont come on at all. The wire seems to run through the loom and connect to a 2nd bolt on the fender along with a bare ground strap. What sort of sorcery has Gm used to make this little light turn on and off?
Oh and running my multimeter from the bolts to the + battery terminal results in 2 different readings... with wire = 12v, without wire = 6v. 3rd my useless Haynes manual proved itself to be even more useless as it has wiring diagrams for every damn light in the car but that one!!
Old Feb 2, 2013 | 05:35 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Under Hood lighting question
The under hood light socket/holder that bolts to the hood has a mercury switch inside of it. You'll have to come up with a switch to turn your leds on and off.
Old Feb 2, 2013 | 06:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yep.
Because the hood is open nearly all day in a car show, I removed mine.
JamesC
Old Feb 2, 2013 | 06:18 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Thanks guys... I noticed this about 10 minutes ago actually. I think Im going to go to Radio Shack tomorrow and pick up a small weather proof rocker switch. Thanks for the replies though.
Old Feb 2, 2013 | 06:54 PM
jermdm's Avatar
Car: 1989 Iroc-z
You could even get a mercury switch from radio shack and wire it to your leds. Take a little fabbing to get it to work.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
