1986 Pontiac V8 tach wiring question
Old Feb 14, 2013 | 12:44 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
I have a 3rd gen (LB9) drivetrain in a Volvo 740 sedan, runs and drives nice, still little things. I have a 4 cylinder tach so it reads high. took cluster apart and disassembled a 1986 Gm v8 tach, I'm gonna be able to mount the GM tach to my Volvo faceplate and needle etc. Just need to know which terminals are which on the tach, they are not labeled. there are 3 connectors, 2 come off tach itself, 3rd is off circuit board. Any body know how to tell which is pos, ground and signal?
Old Feb 16, 2013 | 06:44 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1986 Pontiac V8 tach wiring question
black is ground , white is tacho signal from coil
Old Feb 16, 2013 | 10:09 PM
danclemts's Avatar
yeah, I found that diagram, problem I'm having is which connector on tach corresponds to plus, ground etc. , no labeling on circuit board, just 3 metal tabs, If someone has the gauge cluster, maybe could tell me which color wire goes to which connector. With tach face down, there is a tab, then a space then two tabs close together, first and second tabs have connectors to tach, 3rd just connects to circuit board.
Old Feb 17, 2013 | 02:11 PM
danclemts's Avatar
Pictures are worth a 100 words, First pic shows GM tach connections, second shows Volvo, you can see where they were nice enough to label theirs.
101_0165_zpse5e2b73a.jpg?t=1361118434
Hotrodboba400
Dec 10, 2019 07:07 PM
Gordonr1973
Sep 29, 2015 11:59 AM
tgp1990
Sep 4, 2015 06:24 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
