Fuel Pump, AC Delco or other?
Old Feb 27, 2013 | 11:21 AM
lanman89's Avatar
Car: 1989 Iroc
Engine: 5.7 TPI
I'm about to replace the fuel pump in my 89 Iroc. Has any one had good or bad luck with the AC Delco pump from auto zone? Buying soon so any info would be appreciated.
Old Feb 27, 2013 | 11:14 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Fuel Pump, AC Delco or other?
I buy this one for my under 400 HP third gens...
http://www.ebay.com/itm/NEW-AC-DELCO...db32aa&vxp=mtr
I have one in my 88 V6 Firebird, my mom's 89 TBI Firebird, and my 88 TPI IROC. The original application is for a Vortec 350 in a GMC truck from around 1998 or so. Its a different style pump internally than the original TPI pump, but the TPI engine loves it, and so do the others. Lots of flow. They are just a tad noisier than the original pump but that doesn't bother me. I can only really tell the difference when I first hit the key and it primes up.
It fits in there just like the factory pump, no mods whatsoever. I have bought two of the three I have from the very guy in Miami who has the above listing. So far so good!
Good luck.
Old Feb 28, 2013 | 07:08 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Used Delco EP241 for stockish LB9 recently - no complaints. Fits good, sounds good, works good.
Old Mar 1, 2013 | 08:11 AM
lanman89's Avatar
Car: 1989 Iroc
Engine: 5.7 TPI
Thanks for the info
Old Mar 1, 2013 | 09:06 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
When had the fuel pump done in my TA I went with a Delco pump, so far so good. Stay away from the cheap pumps.
Old Mar 1, 2013 | 09:19 AM
chevelle600's Avatar
Car: '87 IROC-Z/28
Engine: 357 HSR
Axle/Gears: 3:73 w/Eaton Posi
Walbro pump in my z. No complaints. You can hear it prime, and has awesome pressure. Most of te people that have issues with one thing or another is improper install. They dont change the sock or filter, tank should be cleaned etc.
Old Mar 1, 2013 | 11:57 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
That EBAY one from Miami is cheap! Is it a stock replacement or does it flow more? Must flow more than my 305TPI original pump if it's for a 350 vortec truck engine?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
