Please help
Old Apr 1, 2013 | 02:05 PM
transamws6's Avatar
Car: 92 trans am ws6
Axle/Gears: 3.42 ls1 rear end posi
Please help
92 pontiac trans am
My interior lights dont come on anymore and my fuel pump wont prime and when i close the doors the headlights make a clicking noise till it drains batt ...ive checked all fuses and relays all work fine...ive unplugged the headlights connector noise goes away but fuel pump nd interior lights still dont work i checked for volts its 0 nd checked for resistance was very little on headlight connector ...idk wat to anymore help please
Old Apr 8, 2013 | 04:14 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Prime Whine
OK we’ll tackle the pump first because if you can’t get the engine started nothing else matters.
With car the off, jump battery
+ to pin E gray wire
of the pump relay (or the under-hood test connector) and listen for pump whine.
Did the pump run when you did that?
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
