What's the relay on the passenger side near the firewall?
Old Apr 4, 2013 | 09:18 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
I have a 92 RS, with the stock 5.0L 305 TBI.
What's the relay on the passenger side near the firewall? Mine is just hanging loose, attached to a black piece of lightweight metal that looks like it could screw onto somewhere near the passenger side firewall. The relay has 4 wires coming from it, but there is a hole in the plastic on the connector at the B terminal. It doesn't look like there was ever any wire there though.
The two on the driver side are the cooling fan relay and fuel pump relay, right? I took my car to a shop and they kept insisting the passenger side one was the fuel pump relay, but I'm pretty sure they're wrong.
Also I only have one cooling fan for my radiator.. so it's not another cooling fan relay.
Old Apr 6, 2013 | 12:49 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: What's the relay on the passenger side near the firewall?
its not for the fuel pump. Ive seen realys once in awhile on the H-VAC wiring on newer AC cars. My 89 had one till I swaped it out for a Non AC wiring set up
Old Apr 6, 2013 | 08:34 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Fan relay for the Heat/AC
Old Apr 6, 2013 | 09:17 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
I'm thinking it's the relay for the blower for the high speed. Lower speeds run through a resistor setup. Have someone turn the blower on high and see if you can feel/hear the relay pull in.
redmaroz
Apr 25, 2017 07:14 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
