I could use just a little help getting started on my re-wire. I purchased the correct harness for my 89 vert, and i've run all the wires to where they need to go. the fuse box is mounted and im down to actually making hard connections.
im starting at the doors. theres an awful lot of wires in that drivers door, and two wires on the painless harness for the drivers door. ive got a window, and a door locks. so do I gather up pretty much every wire in the door that goes to a switch, and connect it to either the window wire or the locks wire? then ground to the frame?
for the record, I do not have a motor or trans yet, interior is out, oem harness is pulled and I have it, I repurchased all the switches.
I also have a half dozen chiltons books and the factory dealer 8"thick manual.
