Hatch only opens with handbrake up ?
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Hey guys,
New problem my car has developed out of nowhere.
For some unknown reason i can only open the hatch with the button on the dash if the handbrake is up, even with the car switched off ? this is a nightmare now as i have got the knight rider lower console fitted which covers the handbrake
It used to pop the hatch with the car off whether the handbrake was up or down, or if the car was running and the handbrake was on i could pop it then too.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Hatch only opens with handbrake up ?
It's fixed itself, that's how it should work. Stops you popping the hatch while driving.
Car: 1987 GTA
Well the button doesn't work with the engine running. It should pop the hatch with the car turned off and the handbrake down but it doesnt
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Car: 1987 GTA
Thanks Dyno Don, i will have a look in there, i might of knocked something when installing the knight rider console
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
