need to find out where these wires go
Old May 9, 2013 | 03:28 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
they come from the tailhousing of the transmission and they are both red. one looks like it had a connector and the other looks like it was cut. the previous owner said that the speedometer did not work and I think this is the problem.
if you could go to your tpi car and find out where these wires go I would appreciate it.
Old May 9, 2013 | 05:39 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: need to find out where these wires go
They are the VSS signal wires, they should connect back into the VSS buffer then into the PCM. Stock wire colors were yellow and purple, however it could be a transmission out of another vehicle which may not have used the same wire colors. After the buffer, the signal goes into port A10 on the PCM.
Old May 9, 2013 | 09:04 PM
jamon8's Avatar
Engine: 350 tpi
the wires were from a different transmission and I found the original wires
thanks
eightsixseven
Dec 16, 2024 01:50 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Caspar
Jun 19, 2016 11:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
apie2546
Aug 8, 2015 07:12 AM
