gremlins
Old Aug 19, 2013 | 07:20 PM
havacamaro's Avatar
Car: 86 camaro iroc z
Engine: 355 LT1 Full Roller
Axle/Gears: 9 bolt 3.73 posi
gremlins
So I have an unusual problem. Last week I opted to install led bulbs in my car, put them in the tail lights, I pulled the old flasher out, replaced it with a new one. turn signals work great. Come out the next day, and the brake lights are on, but on like running lights on, not like brake lights on(if that makes sense). Also, the car will not start. All accessories come on. Just will not crank. Battery was low but not enough for nothing to happen. I pulled the brake light switch and disconnected it, and the lights are still on, Just the two brake lights, not any of the other running lights. Ideas? I'm out of em, and its hot which doesnt make this problem any easier...
Old Aug 19, 2013 | 08:24 PM
havacamaro's Avatar
Re: gremlins
I got the brake lights to go off but as soon as I plug in the brake light switch again they come back on and stay on for awhile, even if I disconnect the switch. Strange
Old Aug 19, 2013 | 09:49 PM
havacamaro's Avatar
Re: gremlins
ok, another update, now all the brake lights and signals work when the headlights are off, soon as I click on the park lights, the indicator lights up on the dash for left and right, and the blinkers will not work. Please advise, getting closer to figuring this out I think
Old Aug 20, 2013 | 07:47 PM
havacamaro's Avatar
Re: gremlins
so not I've got everything working fine when the headlights are off, but when I turn them on, The indicators come on, and the blinkers do not work. I have replaced the flasher for the indicators and the hazards with electronic ones. One thing i've also noticed is now the side markers arent coming on with the headlights, but they blink with the hazards. Also there seems to be a drain on the battery all of a sudden.
Any help would be appreciated, Super frustrated!
Old Aug 20, 2013 | 11:07 PM
xx138xx's Avatar
Car: 94 camaro
Engine: 5.7 KT1
Transmission: 4L60
Axle/Gears: 10 bolt with 3.73
Re: gremlins
I had a similar problem. My blinkers were acting up when my headlights were on. It turned out to be a bad ground with one of the bulbs. Might be worth it to check.
Old Aug 20, 2013 | 11:09 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: gremlins
Put the filament bulbs back in to confirm there's nothing wrong with the wiring, turn signal switch, etc. and then go from there.
I'm going to take a stab at it and say you have the incorrect LED bulbs installed, i.e, installing a single filament equivalent LED in a socket that needs a dual filament equivalent.
What exactly are you changing to get the lights to kinda sorta work (like you describe above? It might help to post this also.
Old Aug 21, 2013 | 12:16 AM
havacamaro's Avatar
Re: gremlins
well I took your advice and went ahead and put the original bulbs back in the front turn signals and that made everything work again. i'm thinking I have the wrong bulbs, I bought them a long time ago, and just assumed they would work in this setup. Sometimes you have to follow the 2% rule(have to be 2% smarter than the equipment you are working with) So i'm gonna order some correct led bulbs, and give it another whack. No to find the drain. Getting closer.
85f-bird
Jul 10, 2006 08:51 PM
thunderstick
Dec 11, 2005 07:14 PM
BanditWS6
Nov 3, 2003 06:03 PM
rx7speed
Theoretical and Street Racing
Jan 26, 2002 06:45 PM
Adams87Camaro
Jul 7, 2001 08:43 PM
