How do you wire aftermarket gauge lights to your factory dimmer switch?
Old Aug 28, 2013 | 08:22 PM
MeanFbirdT/A's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: LG4 305
Transmission: Borg-Warner T5
Hey everyone. I just installed some aftermarket gauges (oil PSI, temp,voltage, tach, ect) in my 84 Firebird and I was wondering how you install the lights for them to the factory dimmer. I was trying to make it easier then hunting around for two hours with a multi-meter killing my battery. Is there a wire that you plum the positive side of the lights to? Or something else? Thank you!
Old Aug 28, 2013 | 09:51 PM
skinny z's Avatar
Re: How do you wire aftermarket gauge lights to your factory dimmer switch?
In the fuse block there's a terminal marked "inst lps" (or at least there is in mine). I purchased a Pico adaptor and plugged into that slot for my aftermarket gauges. In a pinch you can use a crimp on spade terminal to use as a plug in device. The lights in the new gauges come on with the lights in the dash. What I can't recall at the moment is whether it has the dimming function.
Attached Thumbnails How do you wire aftermarket gauge lights to your factory dimmer switch?-fuse-block.jpg
Old Aug 29, 2013 | 02:31 PM
Engine: LG4 305
Thanks a lot man! Can I just run a wire from that into the positive side of my gauge lights and then chassis ground them?
Old Aug 29, 2013 | 07:12 PM
skinny z's Avatar
Absolutely. You can piggy back the power from terminal to terminal and do the same with the ground. Bring the ground to the nearest piece of steel that makes up the dash support (or wherever you have the gauges mounted).
A little tip I've learned is that if you're using a crimp on male disconnect terminal (the kind that fits over the spade terminal on the gauge), go up a gauge size on the crimp on connector and insert two wires into it. Makes for a very tidy job.
Old Aug 31, 2013 | 09:54 AM
Engine: LG4 305
Thanks a lot for the help, they're all working great! Even have the dimmer function
Old Aug 31, 2013 | 10:49 AM
skinny z's Avatar
Every so often these forums offer up something useful.
Glad I could help.
Old Mar 22, 2014 | 11:09 PM
Justred's Avatar
Car: 1985 Camaro Sport coupe
Engine: 2.8 Multiport V6 (for now anyway)
Transmission: 4 speed automatic
Axle/Gears: 7 5/8 3.42 gears
This is great, I just jumped on to see if I could find this out and the search engine worked perfectly! My Sunpro said hook to the dimmer switch which with my book looks to be the yellow wire coming from the fuse box and column. I spent the day making thinks fit the way I want to I will post some pictures to show the outcome once I am finished
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Dkelz313
Apr 7, 2016 10:38 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
