Digital dash not detecting passenger open door and headlights?
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
So I've discovered this recently developed problem. When I press the digital dash scan car button it detects when I open the left door (beeps on L DOOR) but even though I have the passenger door wide open, it scans through it like it is closed. I've tried wiggling the sensor and everything with no luck. I even tried unplugging the right door senor connector and still didn't pick it up, wouldn't that automatically make the system detect some sort of fluctuation to detect it? I should mention that I just got it back from paint so I don't have the headlights installed (actually not detecting those either
) and the hatch installed (IS detecting that) Could this be down to a burnt fuse or the fact that I don't have my headlights plugged in and the left door sensor is reliant on this? any help would be GREATLY appreciated. Thanks!
) and the hatch installed (IS detecting that) Could this be down to a burnt fuse or the fact that I don't have my headlights plugged in and the left door sensor is reliant on this? any help would be GREATLY appreciated. Thanks! Last edited by Firechicken86; Dec 17, 2013 at 11:37 PM.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Digital dash not detecting passenger open door and headlights?
I even tried unplugging the right door senor connector and still didn't pick it up, wouldn't that automatically make the system detect some sort of fluctuation to detect it? I should mention that I just got it back from paint so I don't have the headlights installed (actually not detecting those either )
I recently did some testing to some of my GTA stuff and at first just had the dash harness connected to the engine harness. The DIC found a problem with the coolant level so I grounded that wire & it didn't pick up any other problems. Then I connected the front headlight harness and it found a problem with one of the front lights.... still nothing at the back or doors. Then I connected the rear harness and it found a problem with a back light. Once the bad bulb was replaced the DIC showed no problems once again.
The whole time my door and hatch sensors were not connected; and no problem was found.
I don't *think* the headlight harness is related to the door sensors in any way. I'm guessing that the right hand door sensor is either disconnected, ( possible broken wire maybe ) or defective.
The_Phoenix
Feb 4, 2016 07:10 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
