92 camaro vss removal possible?
Old Jan 14, 2014 | 05:53 PM
marki's Avatar
Car: 92 camaro rs
Engine: 305 t.b.i.
Hello,
I just purchased a 92 camaro rs with a 305 tbi. Car sat for a few years finally got the engine running a few days ago. While revving it in park i noticed the speedometer pin all the way to the right to the maximum speed on the speedometer then smoke started coming from the center console and knee panel areas. Electrical burning smell. I believe the vss buffer module may have burned. My question is can the vss buffer module be removed and a standard autometer gauge and cable be installed or are these cars dependent on the vss module and i would need to use an electric speedometer. My plans are to eventually replace all the guages with aftermarket autometer gauges but dont know if i should replace the vss buffer or not.
Thanks for your input
Mark
Old Jan 20, 2014 | 10:17 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Need 4 Speed . . . . . . . . . Sensor
If you don’t have or don’t use the Cruise Control you can get away without the buffer.
There are too many to mention types of speedometers to choose from.
Some run using the existing VSS, some use a replacement VSS, some are mechanical.
Just tell your parts supplier you need a speedo for a non-buffer car.
Happy Racing!
I’m Going To Win All My Races In 2014 . . . . . . . . . Or Not
Old Jan 21, 2014 | 06:24 AM
marki's Avatar
Car: 92 camaro rs
Engine: 305 t.b.i.
Re: 92 camaro vss removal possible?
Thanks for the advice. I ordered a new vss buffer and hopefully that will fix my speedometer problem. I would eventually like to upgrade to all autometer gauges in the dash but that won't be for a long time.
Mark
Old Jan 23, 2014 | 05:55 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by marki
can the vss be removed and a standard autometer gauge and cable be installed
Physically it is not a problem ; operationally it may present problems with EFI
https://www.thirdgen.org/forums/post...740-post4.html
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
3rdgenparts
Aug 8, 2015 07:09 PM
