no power to the ignition
Old Jan 19, 2014 | 11:56 AM
barelad69's Avatar
hey guys im new to the forum but not to 3rd gen camaros iv owned my 84 z28 for 16 years and im finally getting a chance to work on it since 2003. so my issue is i just converted it to 5speed from automatic and transferred all the wiring harness from an 85 firebird but now im not getting anything when i turn the key but i have power to everything else am i missing something or did i forget a wire somewhere.
Old Jan 19, 2014 | 08:16 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: no power to the ignition
was there a switch on the clutch pedal to keep the car from starting in gear?
Old Jan 19, 2014 | 09:22 PM
barelad69's Avatar
there is a hole for one but there wasn't anything on the firebird that i took it off of. would it take one? would i need to change out the steering colum to
Old Jan 20, 2014 | 11:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Transformer
Sounds like you didn’t reinstate the Neutral Switch circuit.
On the automatic, the Neutral Switch was mounted to the shifter.
That’s where the wires of interest were.
You need to connect, thru a Neutral Switch, the
purple wire
from the starter solenoid, to the
yellow wire from the ignition switch
Happy Racing!
I’m Going To Win All My Races In 2014 . . . . . . . . . Or Not
Old Jan 20, 2014 | 05:26 PM
barelad69's Avatar
Re: Transformer
thank you nina ill try that.
Old Jan 21, 2014 | 11:19 AM
barelad69's Avatar
Re: Transformer
it worked thanks again NINA.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 27, 2015 07:28 AM
sailtexas186548
Aug 24, 2015 10:11 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
