VSS (Transmission harness swap). SPEEDO DOESNT WORK
Car: 92 Camaro RS
Engine: 350 ci Carb
Transmission: 5speed
i'm pretty sure i've posted about this before, but i'm still having the issue and ive tried everything out there again and again... here's the details
i have a 92 RS. Originally a 305 tBi car with a 5speed.
a while back, silly me wanted to try some FI stuff. So i swapped in the tPi out of a 91z28 (supposed to be a 350 car). auto trans.
so i swapped the wiring harness from the tpi car.
i have 2 wires in the harness but 2 on the VSS in the t-5 transmission.
Since this photo i'm posting, ive run 2 wires from the trans up to the ecu, to color match with the corresponding wires of course.
so, speedo doesnt work.
question i guess is, how do i get to work? which wires should i tap into for the ECM or VSS (clear box) pinout????
any help is much appreciated!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VSS (Transmission harness swap). SPEEDO DOESNT WORK
Terminal B11
http://www.chevythunder.com/fuel%20i...ecm#1227730%29
On a TBI car, the VSS goes to the buffer box then to the ECM
https://www.thirdgen.org/forums/post...777-post7.html
so I suspect you would need to look at both circuit diagrams and see how to wire the ECM output back to the existing IP
TP will be along soon ; he is more knowledgeable about TBI's and buffers
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The tbi vss buffer output can be wired to c6 of the ecm and work with memcal reprograming. Just another thought
Car: 92 Camaro RS
Engine: 350 ci Carb
Engine: Lb9
Transmission: M20
If you need a tbi vss buffer and pigtail lmk
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Problem is that each system uses a different VSS... The TBI more than likely uses a 2000 PPM VSS while the 730 system uses a 4000 PPM VSS.
Only way I found to make both the speedo head and ECM happy was to splice (either join the buffer wires to the ECM wires as they are or splice the ECM wires to the buffer wires, in parallel) the VSS buffer input wires (the yellow and purple ones) BACKWARDS to the ECM VSS input wires. Why backwards, I don't know, but it's the only way I got my speedo head to work and no code 24 from the 730. And this was after just hooking up the VSS as it's supposed to be hooked up to the 730 and using the 730's speedo drive to try to work the speedo head (which didn't work). Without the buffer, the speedo will NOT work unless the VSS is replaced.
This was before I learned that the 730 will accept a buffer input with reprogramming the MEMCAL. Not that that would have helped me since I don't have any way to burn chips...
And yes, I know you have already gone to carb, but this might prove useful to someone in the future.
Car: 92 Camaro RS
Engine: 350 ci Carb
About right?
Engine: Lb9
Transmission: M20
why dont you just wire it like this and hook up a,b a,c,h
if it needs calibration disregard the vss buffer and install a dakota digital agi-5
1992 Trans Am
Aug 8, 2015 08:16 PM
beachrodder
Aug 7, 2015 04:27 PM
