help for diagnostic
Old Feb 19, 2014 | 05:09 AM
thom's Avatar
help for diagnostic
Hello friends, I'm french
I have a scantool innova 3140b
I have in the screen 3 DTC code and I want to erase it.
It' impossible and the scantool not working in a other car.
What the system for erase the 3 DTC code?
on this botom, i'ts a print screen of my computer
thanks
Old Feb 19, 2014 | 05:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help for diagnostic
You don't say what car you have but the usual procedure is to disconnect the battery for 1 minute.
If the codes come back , you have problems that need checking
Old Feb 20, 2014 | 05:51 AM
thom's Avatar
The car is ok
It's the codes in the scantool.
The codes are impossible to erase.
Old Feb 20, 2014 | 02:28 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This isn't really 3rd Gen Camaro/Firebird related, but a Ford DTC 122 (EEC-IV) means low voltage at the throttle position sensor.
Is your check engine light on?
Google "ford EEC-IV trouble code 122" should help.
Old Feb 20, 2014 | 03:04 PM
thom's Avatar
The codes is for my mustang
and I want to scan a Pontiac
just, I want to erase the codes into the scantool
Old Feb 20, 2014 | 03:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You have a scanner problem ; not a car problem which we solve here
So search online for a owners manual for your scanner.
Old Feb 20, 2014 | 03:47 PM
thom's Avatar
Yes it's a scanner problem
In the owners manual I dont have a solution
specialized
Jun 18, 2022 09:26 AM
GTAman
Mar 15, 2019 11:40 AM
mddaniel
Sep 8, 2015 05:16 PM
bowtie1983ss
Dec 4, 2001 12:18 AM
87ColdAirIroc-Z
Nov 9, 2001 04:31 PM
