Headlights keep blowing relays.
Car: 1984 Pontiac Trans Am
Engine: 5.0 305 v8
Howdy, I need some help. My passenger side headlight will actuate up but wont go down, and vise versa sometimes. I've replaced both relays to each headlight motor and to problem will go away for a while but then it'll just malfunction again later down the road (no pun intended). Is there some other reason why this keeps happening? I want to get down to the true root of the cause rather than wasting money on more relays.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Head In The Right Direction
You can disassemble to find out why.
See if the contacts are burned.
See if the coil has opened.
Once you discover which part of the relay is failing you can post to get further info.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Happy Racing!
