(digital dash) F-LAMP getting tripped when hi beams turned on
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
So I've just encountered this rather frustrating issue. When I turn my dash on and the message center scans through everything, F-LAMP is fine and dandy until I turn the high beams on (with the lights on) and then I hear the dreaded beep. It doesn't beep with the low beams on or lights off. Side and park lamps have working bulbs. It's not the headlights themselves as I've tested it with two different pairs and have ran into the same issue. Could there be some sort of faulty relay or dead fuse I should be checking? If someone could help me out on this I would greatly appreciate it.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: (digital dash) F-LAMP getting tripped when hi beams turned on
No firm answers but,...
Bad circuit / bad connection on/@ the Light Monitoring Module ??
Bad wire or connection on headlight connector or inside harness.
I would only dismiss the lights as a culprit if 2 NEW headlights were installed.
I'm guessing that the wires leading away from the headlights and to the LMM could be probed to see if 1 isn't carrying voltage,...... or to discover if the voltages from the left-to-right headlight are comperable ?
P.S. I'm guessing the problem could be in the cluster's DIC "module" too.
Car: 87 Trans Am
i had the same thing check your front blinker and side marker connections mine was the pass side marker
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
