fuel gauge not working properly
Old Apr 24, 2014 | 09:07 PM
tmork454's Avatar
Car: '87 Camaro
Sorry for posting this in the carburetor section. I just used a multi meter on the one red wire coming out of the gas tank (because my car was swapped to a carb by the last owner and they cut the pink tan and black wires that went to the old tank) When i measured the voltage on the pink wire coming from the dash it measured 5 volts. I thought the gas tanks operated on about 3 volts. If thats true how could i lower the current? The fuel sending unit is good because it read around 70 on the ohm meter and im also pretty sure the sending pump is working correctly because the fuel level was working until i put that new intellitronix dash in.
Old Apr 24, 2014 | 10:44 PM
DanzigEx's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: TH700R-4
Re: fuel gauge not working properly
A 300 Ohm Resistor should put you just below 3 Volts, if your getting 5 volts. Although, I'd probably try to figure out why you're getting 5 volts first though! Good luck!
Old Apr 24, 2014 | 11:02 PM
tmork454's Avatar
Car: '87 Camaro
Yeah ill have to follow some wires but in the meantime i can see how that works. Thanks
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
