where does the green wire on fuel pump relay harness connect?
Old May 31, 2014 | 04:29 PM
bucs_gators_fan's Avatar
Car: 1982 Camaro converted into an 87
Engine: 5.7 TPI
Transmission: Manual
im having trouble getting my Camaro running. came home from lunch one day, jumped in my car and nothing. no sound from fuel pump. so I assumed the pump went out. put in a new one. same thing. nothing. put in a relay. same thing. used a jumper wire on the relay the car would fire but not stay running. I then replaced the relay wire harness. still nothing. My budding checked all the wires and noticed that the green wire had no power at all going to the relay. we just need to know where the green wire runs to. or has anyone run in to this problem and it was something else. any help will be much appreciated. thanks. my car is a 87 with a 5.7 tpi
Old May 31, 2014 | 08:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: where does the green wire on fuel pump relay harness connect?
Is the power to turn on the relay from the ECM ;
only has power for 2 sec when the key 1st turned on or after engine starts cranking over
If your OPSU ( fuel pump switch ) is connected and working, the fuel pump should run from that switch as soon as you crank the engine over ;
even with the pump relay disconnected
Typical 3rd gen pump wiring
Old May 31, 2014 | 08:38 PM
Engine: 5.7 TPI
where is the fuel pump switch located at and what does it look like? when I turned the key, the pump will not kick on. the only time I had the pump turn on was with the jumper wire. I have a couple of my friends working on the car who know a lot more then I do. we cant seem to find the reason why the pump wont kick on and the car to run
Old Jun 1, 2014 | 05:47 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Above the oil filter or maybe behind the dizzy
Older style switch has 2 lugs , not the connector as shown on late model switch below
Old Jun 5, 2014 | 07:13 PM
Engine: 5.7 TPI
I found where the green/white wire leades to. its the computer under the dash
Old Jun 7, 2014 | 01:36 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
As I noted above
It should be hot for 2 sec when you 1st turn the key on and when the engine is cranking over
Old Jun 7, 2014 | 08:24 PM
Engine: 5.7 TPI
Originally Posted by vetteoz
As I noted above
ok. thanks
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Caspar
Jun 19, 2016 11:19 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
