87 camaro will not fire, put in new fuel pump and relay
Old Jun 5, 2014 | 04:50 PM
bucs_gators_fan's Avatar
Car: 1982 Camaro converted into an 87
Engine: 5.7 TPI
Transmission: Manual
cannot get my 1987 Camaro to run. one day I jumped in to leave, turned the key, just kept cranking. So then I replaced the fuel pump. still nothing. I even put in a new fuel pump relay and wire harness. still nothing. when I use a jumper wire on the harness, the pump kicks on. when I go to start it the car will start then shut right off. I take away the jumper wire and its back to doing nothing. I have no idea what else to to. I even put in a esc module today hoping that was the problem. still nothing. my car has a 5.7 tpi. any help would be greatly appreciated .
Old Jun 6, 2014 | 05:43 PM
Engine: 5.7 TPI
Re: 87 camaro will not fire, put in new fuel pump and relay
any chance its the ECM?
Old Jun 6, 2014 | 08:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
put in a new fuel pump relay still nothing.
put in a esc module . still nothing..
Checked the fuel pressure at rail ?
What is it , does it hold ?
Old Jun 7, 2014 | 08:23 PM
Engine: 5.7 TPI
that was my next step. im going to try and borrow an ecm from the junkyard and see if that's the problem.
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
