91 speedometer question
Old Jul 2, 2014 | 07:50 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i havet a 5 speed tbi converted to a 92 tpi. after a while the speedo stopped and the car felt like it was in limp mode. i disconnected the battery and reset it and the engine runs fine with no codes.
i switched out the speed sensor with another and nothing. i read somewhere that tpi cars do not use the yellow buffer box. so i should not even have it plugged in.
ive read some threads on speedometer fixes, and want to know where i should start.
Old Jul 2, 2014 | 09:56 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A Speedo Is Good For The Summer
Gain access to the buffer which looks like this:
It’s located behind the instrument panel at the right.
Connect an audio amplifier to terminal A
yellow wire to make sure it’s getting a steady signal.
Ground to ground, the signal wire to terminal A
yellow wire of the VSS.
With the car on jackstands listed for a hum from the amplifier when the rear wheels are rotating.
If you do, then find out if you get a hum from terminal C
tan wire.
The
tan wire then goes to the speedometer unit.
If it gets to the speedometer but the speedometer does not work, have it repaired or replace the unit.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jul 3, 2014 | 02:06 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Re: 91 speedometer question
in another thread it was posted that the buffet box is not used on 91-92 tpi engines. can anyone confirm this?
Old Aug 15, 2014 | 12:31 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
I was wondering the same. Differant sources say yes, other sources say no. Wth.
Old Aug 27, 2014 | 05:24 PM
91 rally sport's Avatar
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
I had the same problem with my iroc. if you look at my thread( speedometer and odometer) Camaro tucker ends up telling me how to repin the harness for the tpi system
Old Aug 27, 2014 | 11:40 PM
tonys91rs's Avatar
Car: 91 Camaro RS
I read it. ill try it this weekend and post results
thanks
Old Aug 30, 2014 | 11:44 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
The VSS is being sent to a dead end at C207. TPI interior harness routes the signal differently than TBI.
TPI sends VSS as a 4,000 signal via the PCM (no buffer box), while the TBI/V6 sends VSS/cruise from PCM as a 2,000 signal which gets converted to 4,000 via the buffer box.
91 TBI converted to 92 TPI, (92 TPI engine harness and computer) (91 TBI interior harness)
speedo, Pin D "GRY" of C207 (clear side) must move to pin k "BRN" (clear side).
cruise, pin E (buffer box) must connect to C207 pin P "red" (black side) (may have to run your own wire for this)
Connect pin F to pin C (buffer box) box can now be removed if desired.
Old Oct 19, 2014 | 03:12 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Is there a diagram for this repinng?
Old Oct 19, 2014 | 05:52 PM
Car: 91 z28
Transmission: 4L60e
Specifically no, you have to sort through schematics.
c207 post #1
https://www.thirdgen.org/forums/ltx-...formation.html
vss/buffer box post #9
https://www.thirdgen.org/forums/elec...-odometer.html
Old Oct 19, 2014 | 09:41 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
when I swapped mine I just moved the brown wire at the white plastic connector to the other side there was a thread about it very easy worked fine
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
