Intermittent Electrical Gremlins
Old Aug 9, 2014 | 09:13 AM
dutch930's Avatar
The car is a 92 RS with 305 TBI, Automatic. Intermittently when first starting I get no electrical power to AC, Dash Fan, Power Windows, Coolant Fan, and Alternator won't charge. Sometimes shutting off the car and restarting fixes the issue and then everything works as it should. Sometimes it will be working fine and while driving it will shut down these items. Is there a relay or something that would have these issues in common?
Any guidance appreciated!
Old Aug 9, 2014 | 10:01 AM
Joe Tag's Avatar
Re: Intermittent Electrical Gremlins
Sounds like a bad ignition switch to me. When this happens again, try just turning the ignition on and off a few times to see if it corrects itself. The will take engine vibrating and getting a loose connection to contact out of the equation. Post back your results and we will go from there.
Old Aug 9, 2014 | 10:32 AM
dutch930's Avatar
Just started it and had no power to the listed accessories. Turned off and on and everything worked. Turned off and back on and the listed items didn't work. I could only get it to repeat itself the one time after trying another dozen or so times. When it wasn't working I got under the dash and jiggled every wire I could reach with no changes. Jiggled all wires again while it was working and it had no effect. Thanks for the help!
Old Aug 9, 2014 | 10:38 AM
Joe Tag's Avatar
Ignition switch is bad. It's not the wires, but the sliding contact in the switch.
Old Aug 10, 2014 | 01:21 PM
dutch930's Avatar
Changed it today. Seems to have done the trick. Thanks for the help!
Old Aug 10, 2014 | 01:59 PM
Joe Tag's Avatar
Good deal. Glad to help.
Grant2k
Apr 4, 2016 08:21 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
lanceflame44
Sep 25, 2015 12:28 PM
