connect power locks to existing alarm
Old Aug 11, 2014 | 03:21 PM
DetroitMuscle21's Avatar
Car: 1986 Camaro IROC Z28
Axle/Gears: POSI 3:73
I recently purchased a 86 iroc z28 power locks power windows ETC. i want to make itkeyless entry with the alarm remote start that came with the car. WHERE DO I START?
Old Aug 12, 2014 | 12:05 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: connect power locks to existing alarm
I would think the first step would be to see if the alarm will support unlocking/locking of the door locks. You'd probably find this info by determining the brand of alarm you have and getting a hold of the installation instructions.
If power door locks are supported, just follow the instructions for hooking the alarm to a "reverse polarity" lock system.
You're on your own from here.
Old Aug 12, 2014 | 05:50 AM
it supports the locks. ill look into now. but wires on the vehicle side would i need to hook up too?
Old Aug 12, 2014 | 04:15 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Well, that's what the instructions/wiring diagram will tell you. Different models/manufactures will be different. With this little info, we can't help you. It's always best to find diagrams and instructions before you know it your car won't start or your lights won't work lol
Old Aug 18, 2014 | 05:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The wires you are looking for are located near the left door under the dash.
Remove the knee bolster to gain access.
The wire
colors are light blue 18 AWG for locking, and black 18 AWG for unlocking.
When you believe you have located the correct ones you can test them with a fused (1 amp is fine) jumper wire, to jump the suspected wires, one at a time, to 12 volts.
The correct wires will lock and unlock the doors.
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is In The Air
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
stalkier
Aug 21, 2015 01:54 AM
