headlight flicker
Old Sep 5, 2014 | 11:25 PM
schroeder178's Avatar
Car: 1989 IROC-Z
Engine: 5.7
headlight flicker
Hey im leaving tomorrow morning for the day and night in my 89 iroc and really quick I need help with my headlights. I replaced the headlight switch and didnt help. Only the headlights flicker both sides after about 10 minutes. And continue randomly flickering. Any ideas? Thanks its gonna be a long night...
Old Sep 5, 2014 | 11:51 PM
aramirez121's Avatar
Car: 1991 camaro rs v6
Engine: v6 3.1
Transmission: auto
Re: headlight flicker
could be your wiring or the pigtails
Old Sep 6, 2014 | 02:01 AM
Car: 1989 IROC-Z
Engine: 5.7
Could it be a bad ground?
Old Sep 6, 2014 | 04:09 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
IIRC, the grounds are up by the passenger headlights.
Old Sep 7, 2014 | 03:45 AM
loopy's Avatar
Car: 1983 Camaro Berlinetta
Engine: L31
Is it both high and low beam?
If one OR the other check the plug under the steering column where it plugs into the dip switch. Mine used to switch on and off and flicker at random and after hours of searching I found one of the retainers broken off the plug allowing it to move in and out of contact. I cable tied it tight into the switch and good ever since.
You'll need to remove the under dash fascia to get at it.
Old Sep 7, 2014 | 01:49 PM
Car: 1989 IROC-Z
Engine: 5.7
Well I got up to the beach and the the dimmer switch is had because the high beams wont click on. Then I ran a jumper from the hot to the low beam wire and taped it up and ran it home so the lights would work, but that plug snd wires got super hot...and the tan wire looks like she got a little hot before. The plugs looked both like they got hot on dimmer and headlight switch. Is it shorting out somehwere maybe??
Old Sep 7, 2014 | 01:55 PM
Car: 1989 IROC-Z
Engine: 5.7
The driver side low beam headlights plug is melted. The tan green wires are both charred and the plug is melted. All other 3 are fine...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
