89 Camaro Rs v6 (Low power to fuel pump relay)
Old Sep 11, 2014 | 05:43 PM
AtomAnt's Avatar
Low power to fuel pump relay. I have tested the orange wire at the fuel pump relay and got 1.5 volts, I have tested the fuse at the fuel pump relay/ecm power and got no volt-edge out of one side. I have tested the fuel pump, and I have put 12 volts to it and got fuel shooting out of the shradder valve. I have spark, crank but no start. I'm thinking it's the ecm. I've checked all fuses and got a new fuel pump relay and new-ish distributor and have checked all wiring. I'm running out of options. I'm looking for help.
Old Sep 12, 2014 | 06:06 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 89 Camaro Rs v6 (Low power to fuel pump relay)
You should have +12 on the orange wire at the relay. Its to be hot at all times. That same fuse supplies +12v to the ecm well. Does your check engine light come on in 'run' ?
Might be a simple' circuit issue, like the fuse holder being bad.
Old Sep 12, 2014 | 08:38 PM
AtomAnt's Avatar
I will check engine light asap i have the same issue in the fuse by the passenger headlight except i get low voltage out of one side instead of none. I will probably replace both fuse holder now you say that just to rule it out.
Old Sep 12, 2014 | 08:41 PM
AtomAnt's Avatar
Also none of the voltages match. They are all different. The only match is in the same Orange at the oil pressure and the fuel pump relay.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
