Mallory hei
Old Sep 16, 2014 | 02:39 PM
Erakhwly's Avatar
Mallory hei
I just installed a mallory hei I am running a 14g wire from the bat to a in line fuse to a switch inside the cab then to the distributer. My question is what size fuse to use? I've heard everything from 5a to 60a. I do not want to fry this coil or melt any wires or dumb **** like that. I put a 10a and as soon as I flipped the switch it poped. I guess I'm going to try a 15 next and work my way up till something works. And no I am not using any stock wiring harness at all on this build
Old Sep 19, 2014 | 07:23 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: Mallory hei
if the fuse burnt, there is a wiring issue. a larger fuse will only cause a fire. Backwards wiring on the coil can cause this.
Old Sep 19, 2014 | 07:51 PM
Erakhwly's Avatar
Re: Mallory hei
Naw I figured out the problem the way the diagram was written is a little funny, it had a ground symbol where the tach is supposed to go, that's y I had no spark. The fuse popped because it was only a 10a and it needed to b 15
2012sergen11
Oct 13, 2015 07:38 PM
skinny z
Oct 5, 2015 06:23 PM
Justins86bird
Sep 27, 2015 09:43 AM
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
