no power to window switch
Old Sep 20, 2014 | 07:06 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
I have a 88 trans am with power windows and recently the windows stoped working. I cant figure out why they would work albeit slow but still worked then the next time i go to work on it they dont work. I checked the fuse but its fine. I pulled the switch and checked with my meter and i dont have any power to any wire in the switch connector i am lost. Every thing else works.
Old Sep 20, 2014 | 08:15 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: no power to window switch
Check if there is power to fuse.
Old Sep 21, 2014 | 09:02 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
"JUMP" the power window motor with power and ground to be sure they still work. Very possible your failing window motors finally gace up and died.
Old Oct 9, 2014 | 08:23 PM
ransam's Avatar
we finally fixed the problem. After checking power to the fuse box as suggested we took the fuse block loose to get a closer look and noticed a heavy pink wire unplugged up behind the fuse block so we plugged it in and everything works as it should. Thanks for the help.
Old Feb 27, 2020 | 10:58 PM
CKone's Avatar
Car: 88 T/A, 91 Formula, 94 Firehawk
Engine: 400 Pontiac, 5.0 TPI, 5.7 LT1
Transmission: 700R4, T5, T56
Axle/Gears: 4.10, 3.42, 3.42
You’re welcome. Now if only those windows needed rolled down
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
stalkier
Aug 21, 2015 01:54 AM
Wylecoyote08
Aug 14, 2015 08:28 AM
