need help with this sensor
Car: 88 bird
Engine: LB8
Transmission: auto
88 LB8 V6 bird. one wire sensor on back of the block next to cylinder 5. it's a dark green/white single wire. I believe it's a fan switch but I'm not 100% sure. and also, where does this sensor tie into the engine harness?
thanks!
thanks!
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Yes fan switch. Should tie in right behind it at the firewall where the harness is.
HoosierinWA
Oct 7, 2015 10:15 AM
