Ground issue??
Old Oct 9, 2014 | 04:25 PM
Shortany's Avatar
Car: 1988 Camaro
Ground issue??
I bought a 84 z28 with a 350. The only problem with it was supposed to be when you drive down the road and slow down, the lights turn off. They said it was probably a ground issue that was easy to fix. Well...I had the alternator tested just in case, and that test came back good. So, I don't even know where to start on a ground issue. Can someone help me out here?
It's a 350, by the way.
Old Oct 10, 2014 | 11:02 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Ground issue??
Elaborate more on what you mean when you say the lights turn off. Are they on but just very dim?
Old Oct 11, 2014 | 12:53 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Ground issue??
The headlight grounds are located just under the "lip" of the front body structure and very easy to access. ( just on the side of the L&R radiator support) Might as well check the battery cable bround (next to the battery) as well as the engine to body ground too ( on firewall above heater lines.)
Doubt it's a ground problem,......
Easy to check: Check your fuse box for burn marks.
Harder to check: Check your headlight switch for burn marks. ( I'm betting the headlight switch or it's connector is burned out. )
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Jae992
Aug 27, 2015 09:07 AM
86Base
Aug 8, 2015 01:34 PM
