no start engine fuel pump quiet
Old Oct 29, 2014 | 09:09 PM
minceycisco's Avatar
I have a 91camaro rs that i believe has a electrical issue. So long story short the starter wires grounded out on the engine so i ended up replacing both battery cables and it crunk up so i turned it off and started working on the water pump because the old one was bad. After i got finish putting it in i went to crank it and it turned over but no crank i also didn'didn't heart the fuel pump Kick on. I disconnected to the battery for a sec and it crunk. But after i turned it off again it hasnt crunk up again. I bypassed the vats i even ran a hotwire from my pump to my battery (pump turn on)but still no crank. The tbi gets power but no pulse ive also replaced the relay. So now I'm lost its like every time i turn the car off now since it burn the wires it doesnt want to come back on. Please help. It has a ls1 350 C1500 engine in it. The pump gets no power when i turn the key
Old Oct 30, 2014 | 08:01 AM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Check for electrical shorts in close proximity to the wires you replaced. Test the fuel pump relay. You can do this key on engine off and jump the 2 hot leads on the relay connector and listen for the pump to run. Another thing to check would be the oil pressure sender as its back up power for the fuel pump relay.
If thats not the proper way to jump the fp relay feel free to chime in. Im assuming you would jump the connector like any other relay.
Old Oct 30, 2014 | 05:27 PM
Re: no start engine fuel pump quiet
Thanks for the reply. I checked all the fusible links and all the fuses under the dash and the cables to start and everything's fine. I took apart the steeri g wheel to try and find the ignition switch but found that it was on top of the steering column I put everything back together and connected all the wires and harnesses back back up and went to crank the car and the car started. The fuel pump also comes on with the key again. I also jumped the oil pressure sender. I think i might have a bad computer because everything is fine one minute and not the next. Ill try it again tomorrow to see if it still cranks hopefully it does.
Old Oct 30, 2014 | 06:08 PM
willexoIX's Avatar
When you give a try tomorrow, pull the ecm but leave it plugged in. Start the car and tap on different parts of the case and see what happens.
Old Oct 30, 2014 | 06:09 PM
Do you know where its located?
Old Oct 30, 2014 | 06:12 PM
willexoIX's Avatar
Should be under the passenger side dash towards the front. If you pull the panel under the passenger side dash, you can look underneath the dash and see the ecm. It should be close to the door if im not mistaken.
Old Oct 30, 2014 | 06:21 PM
Okay thanks ill give your test a shot and see what happens. I will let you know.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
