Need Help
Old Dec 26, 2014 | 02:57 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Need Help
Been working on my 87 iroc tach. bought a tach adpter an no go took the cluster apart an put another tach. in an nothing iam running a 6 al box an hooked to the side everything is right but still cant get it to work. I even went from the cluster of the white wire direct to the box nothing. Does anyone know how if I can hook up from the gage with wires to the box.Thanks.
Old Dec 27, 2014 | 07:46 AM
mr z28's Avatar
Re: Need Help
I guess no one has any answers Thanks for the HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 29, 2014 | 03:35 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
A Tach The Problem
Make sure you’re using the gray wire from the 6AL to the tach or adaptor.
You might have to bypass the tach filter in the dash.
If still no reading, use a stand-alone audio amplifier to hear if the 6AL is putting out as signal.
It should sound like a buzz that goes up in pitch with RPM.
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
