dimming headlights with ac
Old Feb 23, 2015 | 08:27 PM
RSTealer's Avatar
Car: 1991 Camaro RS
Engine: V8 5.0
Transmission: 5 Speed
I notice when I run the ac all lights dim down as well as rpms dropping and it does this and it does this on and off about every 5 seconds.. also idk if its related sometimes on cold starts the car takes longer to turn on rather than right away
Old Feb 23, 2015 | 11:48 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: dimming headlights with ac
May be an alternator issue. I'd have it tested. However my car does this and similar problems but the entire charging system is new. Just wasn't made to handle all the load since ac wasn't even standard
Old Feb 24, 2015 | 08:41 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Check your idle speed for one.
When you turn on the AC, it pulls from the engine and brings the rpm's down even further. The every "5 second thing" is the AC cycling on and off. If it cycles every 5 seconds, it may need a recharge. The pressure sensor on the AC line may be sensing LOW FREON on the system, telling the AC to cycle back off. Then the cycle repeats itself again.
Old Feb 24, 2015 | 08:53 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Feb 25, 2015 | 10:10 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The IAC should step up the idle speed to compensate for the load put on the engine by the compressor.
SRKLEGIN
Oct 29, 2015 06:38 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
