Headlight dimmer
Old Mar 5, 2015 | 09:19 AM
91CamaroZ/28's Avatar
Car: 1991 Z/28 G-92
Engine: 305tpi
Headlight dimmer
Hey guys I have a 91 Z and I think the headlight dimmer switch might be broken. I can't get the lights to switch from low beam to high beam. How do I get into the steering column?
Old Mar 5, 2015 | 06:22 PM
Re: Headlight dimmer
You don't have to.
The dimmer switch is on top of the column, down at the bottom, just a few inches above where it goes through the firewall. Those almost never break. Most likely all you need to do is adjust it: loosen its mounting screws, slide it up toward the steering wheel ¼" or so, and re-tighten the screws.
Old Mar 5, 2015 | 06:56 PM
Car: 1991 Z/28 G-92
Engine: 305tpi
I will have to try.this tomorrow when its not 7 degrees in the garage..thank you
Old Mar 6, 2015 | 04:22 AM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
If you have a tilt steering wheel, try pulling down on it then using the switch. A lot of times the tilt steering wheels wear the housing that holds the pin out, allowing for enough slop to not properly actuate the dimmer switch.
Old Mar 10, 2015 | 09:33 PM
Car: 1991 Z/28 G-92
Engine: 305tpi
Yup the housing is wore out it has a little play and when i pull down a little bit it clicks on and off
Old Mar 10, 2015 | 10:06 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
maybe helpful https://www.thirdgen.org/forums/suspe...-steering.html (How to: Tighten tilt steering w/pictures)
Old Mar 10, 2015 | 10:15 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
My dimmer switch rod had worn a hole the base of the housing on my Formula. I clipped off an electrical butt connector that was bigger than the hole and placed it at the end of my dimmer rod so that it wouldn't push through. Been working fine ever since.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
