What are these things for?
Old Mar 20, 2015 | 09:39 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
What are these for? the black thing is on the passenger side of the car and the red wired plug is on the drivers side. The little black tube that is circled on the second pic does not seem to go anywhere. Should this go somewhere?
Old Mar 20, 2015 | 09:59 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: What are these things for?
First one is EGR solenoid. Second one looks like O2 sensor wire, but I don't think that's the harness loom it should be in.
Old Mar 20, 2015 | 10:12 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Then im assuming those are vacuum lines for the solenoid? One of them is hooked up but the other is not.
Old Mar 20, 2015 | 10:38 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
One of those vacuum lines goes to the ERG valve, the other to a port on the bottom of the plenum.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
