gas gauge reading incorrect
Old Mar 29, 2015 | 11:42 AM
Oncea3fan's Avatar
ok, I am working on a 92 RS 305 tbi,
i been having issues with the speedo but got that straight and I an now zeroing in on the gas gauge.
I have been reading all sorts of problem with the gauges being stuck way over full, but that not my problem.
my gauge registers between 3/4 and just over full, of course when the tank is full it is reading fuel. but when it reads 3/4 it could be from 3/4 to E.
one strange thing is the gauge will float under breaking down to 3/4.
any ideas
Old Mar 30, 2015 | 01:56 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: gas gauge reading incorrect
You need to find out if the gauge or the sending unit in the tank is the problem. When you have the tank 1/2 emptied disconnect the weather pack connector above the rear axle and take a reading with the multimeter on the ohms side. I think our tanks are 0-90 ohm readings, if it is pretty close then the gauge is the problem.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
355sbcTPI
Aug 19, 2015 04:38 PM
BurlyChev
Aug 16, 2015 09:08 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
