Right front parking and side marker lights dont come on, but the blinkers do
Old Mar 29, 2015 | 12:41 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I haven't been able to figure out why my parking light and side marker lights on the right front of my Camaro wont come on but when I turn my signals on they blink fine. Is there a ground some place that I am not finding. I checked the ground wires on the radiator support and they are clean bare metal after I painted my engine compartment.
Old Apr 2, 2015 | 12:21 PM
bigk24's Avatar
Car: 1988 camaro iroc z
Engine: 350 tpi
Re: Right front parking and side marker lights dont come on, but the blinkers do
Change the bulb I know the front blinker had a high and low outage in it and two wires in there try swapping with the other sides bulb and see if it works
Old Apr 8, 2015 | 05:07 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Bright
Due to the fact the right turn sigs work, the ground is good.
You have a bad connection from the left marker lights
brown wire to the right markers.
The bad connection can be a broken wire or at the lamp socket itself.
Happy Racing !
I Didn’t Jump The Start, The Flagman Was Late
Old Apr 9, 2015 | 07:27 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Blown bulb and maybe a little corrosion on the side marker light terminals. Just went through this with one of my cars that has been sitting for 10yrs.
Old Apr 12, 2015 | 06:10 PM
Car: 1991 red Z/28
I changed the right socket out because the ground wire was pulled out of the socket and rotted. That got the turn signals to work. Should I change the left socket too? I also changed both bulbs.
Old Apr 29, 2015 | 12:14 AM
Car: 1991 red Z/28
I got it fixed. I spliced a new brown wire from the left light over to the right brown wire and both the front and side markers work. My temporary fix until I can dig deeper and really fix the problem. Thanks for your help NINA.
Frozer!!!
Jan 19, 2024 04:55 PM
kyleb24
Aug 15, 2015 08:24 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
