Brake light on dash Lower left corner
Old Apr 5, 2015 | 08:21 AM
BuiltZ28's Avatar
What turns this brake light on that is on the cluster, first light on the lower left.
Mine is on all the time.
I thought it was e brake, but not sure if it is anything else.
Old Apr 5, 2015 | 09:25 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Brake light on dash Lower left corner
If that brake light is on all the time it means you have brake problems . So check the pads first. It is not a switch problem.
Old Apr 5, 2015 | 09:35 AM
BuiltZ28's Avatar
any more info on what triggers it? let me add their is no ecu in the car
Old Apr 5, 2015 | 11:48 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Cluster swap ??? ( not all 82-89 clusters are plug & play compatable )
BRAKE light is normally activated by a switched ground signal.... from either the parking brake handle switch or the Pressure switch on the MC.
Old Apr 5, 2015 | 12:10 PM
BuiltZ28's Avatar
ok thanks its original cluster i will have to dig into it
Old Apr 5, 2015 | 02:46 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
How does the car stop compared to how it used too. Or has the light been on since you got the car? Look for brake fluid leaks especially at the wheels. Try jacking up the back so the wheels are off the ground and (on axle stands) run the car in gear (park brake off) and see if the brakes stop the back wheels. Then you could try jacking the front wheels and spin them and check the brakes. If the brakes won't stop one or more of the wheels it narrows down the issue. If the wheels all stop quickly that MAY not be the issue. Then dig into the center console and find the connection to the e-brake and check it is operating correctly when the lever is on/off. Then....
Old Apr 5, 2015 | 05:38 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Just to add what others have posted.
Assuming that the brake light warning circuit is functioning properly, the brake warning light has two functions. When it's illuminated it means:
1. The parking brake is on or not fully released. If the parking brake is released and the light is on, most likely the switch is bad. I don't recall there being an adjustment for this switch.
2. A fluid pressure difference has been detected between the front and rear brakes. This means there's a brake fluid leak someplace.
The light is not connected to any kind of brake lining wear sensor.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
