1990 IROC 5.7 Gauge Cluster: Speedometer "sticks", Fuel always at "F"... F!
Old Apr 7, 2015 | 12:02 PM
j_huerta22's Avatar
Car: 1990 Chevrolet Camaro IROC-Z
Engine: 5.7L TPI
I recently replaced the broken 145 gauge cluster on my IROC with a working 145 gauge cluster. No complaints other than the speedometer tends to be off and it sticks at 35 and 60 MPH. Does this mean I have a VSS going out, or is there something in the gauge cluster itself?
Also, the fuel gauge worked while driving, but then it began to read that it was full all the time. Knowing that 5.7 doesn't run on hopes and dreams, would that also be an issue with the cluster or the sensor?
Any information you can provide would be much appreciated!
Old Apr 7, 2015 | 03:26 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: 1990 IROC 5.7 Gauge Cluster: Speedometer "sticks", Fuel always at "F"... F!
Pegged gas gauge is usually a bad ground.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
jharrison5
Aug 19, 2015 05:53 PM
ChevyZ71
Aug 13, 2015 07:30 AM
mustangman65_79
Aug 11, 2015 03:17 PM
