1991 RS Problems
Old May 6, 2015 | 05:16 PM
Rmurphy70590's Avatar
1991 RS Problems
I just bought a 1991 TTOP RS from a friend of mine. The cars been ripped apart and not too sure where certain things go. I was having a problem getting the fuel pump to work. Found out it was a bad ground. I just discovered that the ground is supposed to be bolted somewhere on/around the rear seats. The seats are out so i'm guessing that's why the ground doesn't work. i'm wondering if anyone has a picture of the location of where the ground should be. Also when i'm cranking the car over, my gauges go crazy and then pin all the way up when its running. Anybody know whats wrong? Thanks in advance for any answers/help.
Old May 8, 2015 | 11:02 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 1991 RS Problems
You most likely have ground problems, plural. You can ground the fuel pump anywhere where can make a good ground though the thicker the metal the better. Check all the main grounds for corrosion and tightness. Make sure it is bare metal with a star washer where it is grounding too. Go over to www.austinthirdgen.org and take a look at the wiring schematics they have posted.
jhawkeye
May 25, 2022 06:33 PM
bjpotter
Jan 22, 2019 12:27 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
