Two things I need help with (FANS/ACCESSORY)
Old May 20, 2015 | 06:44 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello everyone, I recently bought a clean, near mint 88 Iroc G92/5 speed from Texas. And although very clean, it has its share of issues.
My main concern is that I don't seem to have an Accessory mode on my ignition. I am a fan of my music, and I like to sit in my car and enjoy it sometimes and I would really like for this to be functional again.
Fixed one issue.
Any help would be welcome. Thanks!
Old May 20, 2015 | 10:49 AM
prettybad92rs's Avatar
Engine: 5.0 Liter EFI V8
Axle/Gears: 2.73 Ratio GU2
Re: Two things I need help with (FANS/ACCESSORY)
If your running after market head unit, power it up to your fuse box. There's a single pin circuit marked radio. Or another single pin circuit marked auxiliary. Either circuit will supply power with ignition off. Don't forget to run a fuse.
Old May 20, 2015 | 11:01 AM
Annihilate's Avatar
Engine: 5.0
Would giving it constant power like that drain the battery at all?
Old May 21, 2015 | 03:04 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Those connections will only send power when the key is in "Accessory" position = ACC and "ON" position.
Old May 21, 2015 | 05:59 AM
Annihilate's Avatar
Engine: 5.0
Isn't our ACC behind the "Lock" area?
Old May 21, 2015 | 01:55 PM
Engine: TBI,5.0
Its Lock, ACC, ON, then Start just like the photo shows.
At least it is on mine.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
