Wondering if other members have same experience
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
My power windows in my 89 GTA run soooo slow in either direction, (up or down, passenger and driver's side as well), and wondering if any one else experience this ? Pulled the door panel and checked for binding and greased the linkage. Even reving the engine didn't help.
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Wondering if other members have same experience
They're electrical so assuming you have a good battery, reving the engine will have no effect. Take the motors out & clean the gearing thoroughly. Put lithium grease on the gears & bench run them several times to check. Re-install & walla!
NBrehm
Aug 5, 2015 07:57 PM
