Driver window winder motor
Car: '82 Camaro
Engine: 305ci (SUJ) not crossfire
Transmission: TH350
Axle/Gears: Stock
The other one works ok with a resistance of about 1.9 ohms but the driver does not work at all and the resistance does not settle on my dmm.
Before I take out the motor for checking, is there anything I should look out for?
It seems to be riveted in. Can I drill them out?
The switches work properly..
Car: '82 Camaro
Transmission: TH350
Axle/Gears: Stock
Re: Driver window winder motor
I repaired the motor. It was full of grease. No idea why or how it got in. I was also able to turn the brushes as they appear to be reversible.
Reassembly of the motor and actuator was a bind, but refitted it with two 4mm rivets where there were 1/4".
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
