If my ground wire is broken...
Old Jun 5, 2015 | 06:04 PM
julyburnsred16's Avatar
The ground wire running from my negative battery terminal to the frame of the car is broken. Am I ok to run my car with it like this? If it needs to be fixed, is there a way to just mend it, or does it need to be replaced? If it needs to be replaced, where can I get my hands on a new wire?
Old Jun 5, 2015 | 06:34 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: If my ground wire is broken...
Everything electrical needs a ground to complete the electrical path. Get it fixed and fixed right. Take it off and go to an auto parts store.
Old Jun 5, 2015 | 07:41 PM
If your ground wire is broken, fix it.
How basic can something like this get?
You can cut off whatever is broken about it, and splice on a new piece of BIG FAT HEAVY wire, like #10 or so, with BIG FAT HEAVY-DUTY terminals.
If it's broke at the battery, get a new neg batt cable. It's like $8 or something. Less than you spent on lunch today. Not worth getting all worked up about. Just do it.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Glowsock
Aug 26, 2015 12:28 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
