What are these?
Old Jun 27, 2015 | 07:23 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
What are these?
HI,
I found these 2 connectors loose in my engine bay, one burn and the other with a loose nut right on top(bronze in color). Anybody know what they are? Any help appreciated.
Attached Thumbnails What are these?-loose-bronze-mail.jpg   What are these?-burn-switch.jpg
Old Jun 28, 2015 | 03:50 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: What are these?
The one in the left photo is for an aftermarket, mechanical temperature gayge.
The connector in the right photo looks like it might go to the coolant temperature sensor.
Edit: The connector in the right is for the radiator fan switch.
Old Jun 28, 2015 | 12:25 PM
podiatra's Avatar
Engine: 350 swap
Re: What are these?
So the one for the mech gauge, is suppose to be connected some where? The car does have a working mechanical gauge installed by thhe preious owner.
Old Jun 28, 2015 | 12:50 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: What are these?
The bulbous tube would be threaded into a bung in your intake. Likely got changed at some point.
Old Jun 28, 2015 | 01:47 PM
robotic_junky's Avatar
Car: 1991 Firebird
Engine: n/a
Transmission: n/a
Axle/Gears: 3.27, I think
Re: What are these?
Old Jun 28, 2015 | 04:21 PM
podiatra's Avatar
Engine: 350 swap
Re: What are these?
Got t. Thanks I will need to find the bung. It make sense that the 2nd pic in for the radiator fan switch since the previous owner of the car put a switch to manually turn off/on.
