No injector pulse. 1991 L98 TPI
Old Oct 6, 2015 | 10:04 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I posted this in 2 other forums that applied.
I'm getting no injector pulse (checked with Noid light). I am getting plenty of spark. MSD 6A box seems to be wired correctly.
I installed a brand new distributor and set the timing on crank to 0. I tried the firing order 180 the other way in case I wasn't TDC.
New FPR and im trying to set it (unhooked, and hooked up to vacuum lines). I can hear the fuel pump when I turn key to the on position and it hits 40 and drops off slowly. Fuel pump does not come on any more as I turn it over.
I installed new AFR aluminum heads and pretty sure I regrounded the straps and wires attached to the old heads to the block.
I also deleted all the smog equipment..EGR, vapor canister, vacuum lines, plugged all vacuum leaks, etc. I put a breather on the gas tank vent.
Deleted the cruise control and vacuum ball. Deleted the AC, and the heater fan (for now) unplugged a lot of connectors to the heater stuff.
Electric fans are wired to a manual switch. Stock wires are unplugged.
*Sensor that is on the passenger side head is unhooked. I plugged the head when I couldn't find the sensor. I thought it was for the fans to turn on so I didn't buy a new one.
*I am using the stock chip. This chip was sitting in a plastic bag for 15 years. I sent the PROM I was using the past 15 years back to TPiS for a new tune reflash for the heads and intake port work I did.
Im not getting a security code
My questions for no injector pulse:
Do I have something unplugged or deleted that is causing this?
Is it the stock PROM?
My timing too far off cause no injector pulse?
Does low fuel pressure cause no injector pulse?
mddaniel
Aug 16, 2016 03:21 PM
91L98Z28
Oct 28, 2015 11:42 AM
tuningnewb
Oct 11, 2015 05:28 AM
2QUIK4U
Oct 8, 2015 06:40 AM
tuningnewb
Oct 3, 2015 11:57 AM
