MAF to SD (I've searched)
Old Oct 22, 2015 | 09:28 PM
L98GTA87's Avatar
Car: 1987 Trans am
Engine: 350 Vortec Stealth Ram
Axle/Gears: 02 SS Torsen Zexel 3.42
I know this is asked frequently but I couldn't find a direct answer. I'm looking to go from maf to SD. I don't want to repin and use the maf harness because it's in question. I have the SD ECM and access to the full SD ECM harness. Is this a straightforward swap over or is it not that simple?
Old Oct 23, 2015 | 07:17 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: MAF to SD (I've searched)
Most should be straight forward.
One gotcha will with the C207? connector near the ECM, that connects the ECM harness to the underdash harness. It is a 6 cavity connector and contains injector power (2), backup light circuit (2, if manual trans), and possibly 2 others. So, maybe a little re-pinning there.
Old Oct 23, 2015 | 01:49 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You should not even try to put plug a SD harness into an '87, to many different connections.
Your best bet is repin.
Old Oct 29, 2015 | 07:45 PM
L98GTA87's Avatar
Car: 1987 Trans am
Guess I'll have to find another 87 harness
MustangEater82
Oct 30, 2015 09:16 AM
legendaryhero7
Oct 23, 2015 08:27 AM
f68
Oct 22, 2015 05:48 PM
f68
Oct 22, 2015 05:44 PM
legendaryhero7
Oct 22, 2015 09:23 AM
