87 gta tach wire location
Old Dec 26, 2015 | 12:09 PM
timonator's Avatar
Im trying to connect my tach to my ls1 pcm but I dont know exactly where to find the white tach wire to connect to in the dash. Could someone help me please ?
Old Dec 26, 2015 | 07:00 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: 87 gta tach wire location
Might vary based on year, but for my 89 the Tach wire is D6 on the C100 connector. This connector is the weather pack connector located on the firewall right next to the Brake Booster.
C100 Diagram
Old Dec 29, 2015 | 06:05 PM
timonator's Avatar
Ok, found it. thanks
Old Dec 31, 2015 | 06:30 PM
Pocket's Avatar
Car: 91 Trans Am
Tach at D6, Oil pressure at E5, Coolant gauge at F5
All remained the same for all 3rd gens regardless of year and drivetrain
Old Jan 1, 2016 | 07:58 AM
timonator's Avatar
Pocket, in order to make my tach work I need to hook up a 12v ign wire with a 1k resistor to the white wire, right? Is that all I need to do or is it also necessary to make changes with hptuners ?
Old Jan 1, 2016 | 09:55 AM
Pocket's Avatar
Car: 91 Trans Am
Most firebirds require a step-up booster wire. I use a 680ohm resistor hooked to a fused 12v IGN source, but there isnt a set rule for how much it needs
You also need to change the tach output from 4cl to 8cyl
etizz
Feb 1, 2016 08:55 AM
Bddbrd86
Jan 26, 2016 04:48 PM
db057
Dec 24, 2015 07:11 PM
Berj83
Members Camaros
Dec 24, 2015 11:19 AM
alex722607
Dec 24, 2015 12:21 AM
